It is currently Sat Jul 26, 2025 8:29 am
PostPosted: Fri May 13, 2005 9:55 pm
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
I'm moving into my new place. There is some gold flocked wallpaper in one roof and some red flocked in another. I wonder if the lady from whom I purchased the house ran a bordello-ahhh, if the wallpaper could talk. The paper has been put up with a glue. I am wondering is renting a steamer still the way to go?
PostPosted: Fri May 13, 2005 11:50 pm
You can buy a cheaper model at a Home center. You can also prep the wall paper by scoring it with a special tool and applying wall paper removal pre treatment product also available from a home center. Then you just have to put in your time with a spatula and the steamer.
PostPosted: Fri May 13, 2005 11:53 pm
Get the scoring tool from the home center. It's a small roller with lots of tiny blades and you just roll it over and over the paper. Then you spray on a special wall paper remover that softens the glue. The tiny slices allow the spray to get in there and soften the glue. Worked like a charm for me.
My folks almost burnt down the house with a industrial wall paper steamer so I'm a little leary of those.
PostPosted: Sat May 14, 2005 12:52 am
It depends on the age of the paper and what was used as or instead of paste. We removed paper just fine by using just the special enzymatic removal liquid. Others have told me horror stories about some wallpapers that were glued (not pasted) on and defied everything. You definitely want to go slow and avoid damaging the wallboard/drywall that could require a lot of work patching and sanding. Unfortunately, it's not a fun job no matter what you use.
PostPosted: Sat May 14, 2005 1:10 am
Last Name: Johnson
State: CO.
Thanks so much guys.
PostPosted: Sat May 14, 2005 8:25 am
I just ended up sanding off a border in our bathroom. Fortunately, it was a small room. The glue would feed mold, but you couldn't soak it off with the wallpaper glue removers or anything else for that matter. Such a lovely combination. Be careful if you use any of those borders to get a reputable brand that says its glue will not support mold.
PostPosted: Sat May 14, 2005 9:05 am
We use a garden type pump sprayer filled with hot water and a couple of cups of vinegar. Thoroughly wet the wallpaper and let the water soak in for a few minutes then scrape off with a putty knife. We use this method in our rentals.
tim...
PostPosted: Sat May 14, 2005 9:38 am
I'm with Tim. Vinegar does the trick.
PostPosted: Sat May 14, 2005 5:12 pm
[QUOTE=bob J] I'm moving into my new place. There is some gold flocked wallpaper in one roof and some red flocked in another. I wonder if the lady from whom I purchased the house ran a bordello-ahhh, if the wallpaper could talk. The paper has been put up with a glue. I am wondering is renting a steamer still the way to go?[/QUOTE]
Don't feel too bad. A visitor to our current house referred to the downstairs bathroom as decorated in the style of "Early Steak & Ale" . The master bath was lime green and lemon yellow! Needless to say, things have changed.
Steve Brown
PostPosted: Sat May 14, 2005 5:13 pm
[QUOTE=Pwoolson] Get the scoring tool from the home center. It's a small roller with lots of tiny blades and you just roll it over and over the paper. Then you spray on a special wall paper remover that softens the glue. The tiny slices allow the spray to get in there and soften the glue. Worked like a charm for me.
My folks almost burnt down the house with a industrial wall paper steamer so I'm a little leary of those. [/QUOTE]
"Paper Tiger", I believe.
PostPosted: Sun May 15, 2005 1:56 am
Vinegar and hot water worked for us too. Just remember to go slow so the solution has enough time to soak in.
PostPosted: Sun May 15, 2005 3:01 am
[QUOTE=highdrawlicks] Removing the paper is going to cut into valuable luthiery time. My advice, torch the place and buy a new home sans offending wallpaper with the insurance money. One must set his/her priorities in life. [/QUOTE]
GREAT!!!
PostPosted: Sun May 15, 2005 10:10 am
Might be a hard sell for the insurance company when they discover that all your tonewood was rescued from the fire.
PostPosted: Sun May 15, 2005 1:33 pm
[QUOTE=highdrawlicks] Insurance companies--yes--well--. WhenI torche--I mean, when my last abode burned to the ground (we think it was caused by a pocket of swamp gas ignited by the tail of Comet Hale Bopp) , I tragically lost thirty sets of exquisite old growth Brazilian, and two dozen of African Blackwood. The adjuster who examined the surviving, badly scorched sets claimed they suspiciously resembled poplar in both density and grain pattern. However, after impressing him with my integrity, and he approved my claim. He is now the proud owner of a matched set of six and twelve string cutaway Propsom guitars. Hey, there's a solution to everything. [/QUOTE]
PostPosted: Sun May 15, 2005 2:15 pm
First name: R
Last Name: Coates
City: Selma
Sounds like my grandmother's house in about 1970... Not in Gladstone MO is it?
Oh and don't feel bad. The house I bought last had LOOONG shag carpet in every bedroom... One blue, one red, one purple and one pink!RCoates38487.9702546296
PostPosted: Wed May 18, 2005 11:00 pm
Last Name: Johnson
State: CO.
Torch it! Greaat!
PostPosted: Thu May 19, 2005 6:52 am
I just saw some show on diy where they redid a bathroom that had that "Old Car" wallpaper. The one with various steamer era cars on it. After scoring with the paper tiger they put some sort of paper soaked in glue softener over top the original paper for a while and then after carefully working a corner loose the whole thing peeled off in one sheet clean as a whistle. I don't recall them giving a brand name but the guys at the BORG should know what you're talking about.mcrandello38491.6623611111
